10-02-2023
		13:06
		04:37
		10-02-2023
		13:06
		04:37
How do I locate my Versa 2 through the app?
10-02-2023 13:09
                              10-02-2023 13:09
Or any other free Bluetooth locator phone app, but must be done before Fitbit battery runs out.
 Best Answer10-02-2023 13:12
10-02-2023 13:12
Okay thanks, its definitely syncing, I'll try the app.
 Best Answer10-02-2023 13:15
                              10-02-2023 13:15
That means within bluetooth range - about 30 feet.
 Best Answer10-02-2023 15:16
10-02-2023 15:16
Okay, I had to get the paid version on the Bluetooth finder app to find it but found it! Thanks!
 Best Answer10-02-2023 17:32
                              10-02-2023 17:32
Oh well; haven't tried them for a while. There's probably a free one that works but I expect worth a few dollars to just find it and avoid too much trouble in the process. Glad you found it at least.
 Best Answer10-03-2023 06:25
10-03-2023 06:25
Correct! It was only like $4.00. I was just a tad frustrated because it took me a minute to figure out I had to pay for it to work. Otherwise, I would of just paid first and save some time. Once I paid, I found it in less than 10 minutes. 😊 Thank you!
