05-14-2018
13:03
04:34
AlejandraFitbit
05-14-2018
13:03
04:34
AlejandraFitbit
Hi all. I have been using my Versa for a few days now, but I have some disabilities and I can only exercise in the pool. I take part in four or five Aqua aerobics classes a week, but as yet, I haven't been able to get the versa to track my exercise properly.
I've tried it on the workout shortcut, but it cuts off after a while, I think because my classes are an hour long and continuous. I've tried swim mode but this doesn't work either? I am going to try the circuit training mode tomorrow, but I wonder if anyone has any suggestions?
Its quite important that I track my heart rate and calories burned while exercising, which is why I got it in the first place, after using my Flex 2 for a year. Thanks
05-18-2018
04:36
- last edited
10 hours ago
05-18-2018
04:36
- last edited
10 hours ago
Hey @siouxabbs, a warm welcome to the Forums.
Thanks for troubleshooting this by yourself. Have you tried to manually log your exercise? If you haven't, I recommend manually log it by doing the following from your Fitbit app:
I hope this helps, let me know the outcome.
06-24-2018 12:36
06-24-2018 12:36
@AlejandraFitbit I thought the Versa was supposed to be able to accurately log water aerobics WITHOUT having to manually enter the workout. It is the whole reason I got the Versa. If this isn’t the case I will return the Versa. Is there not a way to have it log water aerobics accurately without having to manually add it? When I had my Alta I had to manually add it since the Alta isn’t water resistant. It would my heart rate would be around 111 (which I know is an average for water aerobics) however I know that mine gets higher. I wanted the Versa as I thought it would give more accurate information. Should I just return the Versa?
06-24-2018 13:05
06-24-2018 13:05
07-04-2018 12:32
07-04-2018 12:32
08-14-2018 08:00
08-14-2018 08:00
My understanding is that the Versa will auto-log laps swam in pool, but not water aerobics. I use My Fitness Pal to log my workouts since it syncs with my Fitbit, and Water Aerobics is a category that calculates ur calories burned by duration along with ur profile info (height/weight/gender ).
08-16-2018 08:25
08-16-2018 08:25
Hi, I am in exactly the same predicament. I do several aqua classes (general fitness and zumba), my old fitbit flex 2 (at about $50!) had a setting for water aerobics, but not my new versa (at $200!). I do not care about having music and notifications, I just want to track exercise and food
08-23-2018 16:28
08-23-2018 16:28
10-31-2018
13:50
05:17
JuanJoFitbit
10-31-2018
13:50
05:17
JuanJoFitbit
I used my Versa for the first time in a Water Aerobics class today. It also cut off after 47 minutes. The strange thing is after it dried out...it synced with my phone & the 47 minutes are logged in the app but don't show up on the watch itself. Which is frustrating to say the least & to add to the misery.....what about the last 15 minutes?!?! I bought the Versa coz I honestly couldn't afford a Garmin....but 3 weeks into my purchase I'm totally regretting it.
Forgive me for saying so...but this is a non-response. Manually tracking an exceedingly could have been done with many apps that did not require the purchase of a Fitbit Versa. The whole point is to have the accuracy.
Moderator edit: merged reply
11-15-2018 10:32
11-15-2018 10:32
Hi I also do aquafit class and I use the workout mode to monitor my exercise. It is pretty accurate and works well. I hope it help. 😀
11-15-2018 12:44
11-15-2018 12:44
12-17-2018
20:58
05:19
JuanJoFitbit
12-17-2018
20:58
05:19
JuanJoFitbit
Just used my new charge 3 for aqua fitness and very disappointed it was a hard class and my calories burned showed 198 for the hour I set it at swim but obviously that didnt work on my garmin I used to use "other" bu tdont know with this ....I only bought it because of the swim mode I thought it would recognize it ...maybe return it and go back to my garmin
I tried this but only 212 calories are showing up for an hr high intensity workout this is totally inaccurate.
I tried manually log ging it as was suggested but only 212 calories are showing up for an hr high intensity workout this is totally inaccurate I am really confused now and on my tracker I only have the options to run elliptical lift weights or swim
not impressed with it at all
12-18-2018
07:32
06:08
JuanJoFitbit
12-18-2018
07:32
06:08
JuanJoFitbit
You have to use the workout setting for aquafit.
Use the workout setting for the class
Sent from my iPhone.
12-18-2018 07:50
12-18-2018 07:50
12-18-2018 08:54
12-18-2018 08:54
12-18-2018 09:38
12-18-2018 09:38
12-18-2018 09:40
12-18-2018 09:40
12-18-2018 09:41
12-18-2018 09:41
12-23-2018 05:45
12-23-2018 05:45
@Slynny The versa only has default exercises on it, there are more if you go into the app. I haven’t looked for the aqua fit yet. I don’t remember seeing that previously though.
12-23-2018 06:33
12-23-2018 06:33
