03-31-2021
10:30
20:47
03-31-2021
10:30
20:47
How do change an alarm with Fitbit Premium. option no longer available on phone app.
03-31-2021 11:04
03-31-2021 11:04
On Versa 3 alarms are on the device itself rather than on the phone app. From main clock face, scroll right through apps to 'Alarms'.
This is true with or without Premium.
Best Answer03-31-2021 11:04
03-31-2021 11:04
Best Answer04-04-2021 07:26
04-04-2021 07:26
I have several silent alarms that pop up that i did not set. They are not seen on my list of alarms on the clockface. How do I delete silent alarms???
Best Answer04-04-2021 07:55
04-04-2021 07:55
@SunsetRunner wrote:I have several silent alarms that pop up that i did not set. They are not seen on my list of alarms on the clockface. How do I delete silent alarms???
In the 'Alarms' app on wrist, tap the alarm you want to delete, then scroll down to bottom and there is a 'Remove' option.
I think you have to delete them one at a time.
04-15-2021 11:54
04-15-2021 11:54
Thanks you!! that did the trick!
Best Answer05-07-2022 05:52
05-07-2022 05:52
I want to thank JohnnyRow for helping me
find a way to remove alarms. Thank you.
