03-31-2021
10:30
20:47
03-31-2021
10:30
20:47
How do change an alarm with Fitbit Premium. option no longer available on phone app.
03-31-2021 11:04
03-31-2021 11:04
On Versa 3 alarms are on the device itself rather than on the phone app. From main clock face, scroll right through apps to 'Alarms'.
This is true with or without Premium.
03-31-2021 11:04
03-31-2021 11:04
04-04-2021 07:26
04-04-2021 07:26
I have several silent alarms that pop up that i did not set. They are not seen on my list of alarms on the clockface. How do I delete silent alarms???
04-04-2021 07:55
04-04-2021 07:55
@SunsetRunner wrote:I have several silent alarms that pop up that i did not set. They are not seen on my list of alarms on the clockface. How do I delete silent alarms???
In the 'Alarms' app on wrist, tap the alarm you want to delete, then scroll down to bottom and there is a 'Remove' option.
I think you have to delete them one at a time.
04-15-2021 11:54
04-15-2021 11:54
Thanks you!! that did the trick!
05-07-2022 05:52
05-07-2022 05:52
I want to thank JohnnyRow for helping me
find a way to remove alarms. Thank you.
