05-02-2018
09:24
09:14
AlejandraFitbit
05-02-2018
09:24
09:14
AlejandraFitbit
How do I factory reset my Versa? Wipe it off.
02-21-2019 18:23
02-21-2019 18:23
@krypro I think at this point I would definitely reach out to Customer Support. It might be a faulty device.
Best Answer02-22-2019 17:38
02-22-2019 17:38
I'm trying to reset my Versa to factory settings but it keeps giving me the message that it can't clear all the data and to sync again, but now it wont/can't sync. It's just frozen. Any tips?
Best Answer02-25-2019 07:06
02-25-2019 07:06
Great advice. Did work for me. As I have a dock to charge with I started from step 2 and it perfectly worked. Thank you .
Best Answer03-03-2019 02:33
03-03-2019 02:33
how did you get the reset done ?
Best Answer03-03-2019 11:54
03-03-2019 11:54
Best Answer03-12-2019 23:43
03-12-2019 23:43
Mine is the same issue as yours where I have tried to reset the factory settings with the three buttons and mine doesn’t reset at all... can anyone help I’m out of ideas??
Best Answer03-25-2019 11:03
03-25-2019 11:03
How do you hold all three buttons while it's on charge if you can't reach the buttons while it's on charge?
Best Answer03-25-2019 14:30
03-25-2019 14:30
unfortuantly I cant unlock it that way because my fitbit versa is stuck on a lock screen and keeps saying to have my phone unlock it so I'm not sure what to do
Best Answer04-02-2019 17:14
04-02-2019 17:14
After my factory reset, my versa does nothing but show the fitbit logo and say to download the Fitbit app. How do I do that when the Fitbit isnt responding?. Please dont say place the watch in the cradle and press the 3 buttons. This step can not be done while in the cradle and why must the watch be in the cradle in the first place?
Best Answer04-09-2019 18:30
04-09-2019 18:30
I tried everything you tell, it just didn’t work. Is there a better way. Also mine doesn’t stay charge for 4 days like it says. Can I return it with it not being reset to factory
Best Answer04-09-2019 18:35
04-09-2019 18:35
I tried everything you suggested just didn’t work. Please help me or I’m going to return it.
Best Answer04-10-2019 03:26
04-10-2019 03:26
Best Answer04-10-2019 09:20
04-10-2019 09:20
I had to call Fitbit for help with mine. It took a very long time to get it reset and it has happened again. I'm done with the Versa. I'm calling it the best ad for Garmin I've ever seen.
Best Answer04-29-2019 11:18
04-29-2019 11:18
Just joined the forum to say: If you're trying to reset your Versa because it's stuck on the lock screen (which seems a common fault you'd think they'd fix, or at least add a warning screen that you've put the wrong number in), DO NOT UNPAIR IT FROM YOUR PHONE. Part of the re-pairing process is typing a 4 digit number from the watch screen into your phone, but you won't be able to see it because the screen is locked. My watch is useless now, and won't factory reset either. Tech support were no help, and they won't cover purchases made through eBay even if they're new. I wouldn't have bricked my watch if their help guides were in any way useful in the first place. I'm really sick of companies skimping on technical help and just getting customers to talk to each other on forums instead.
06-03-2019 05:14
06-03-2019 05:14
Hi i tried what everyone has said and still could not reset it on the versa could you please help
Best Answer06-03-2019 08:41
06-03-2019 08:41
Best Answer06-03-2019 09:37
06-03-2019 09:37
Best Answer06-03-2019 10:13
06-03-2019 10:13
I did call the company and they were helpful. After an hour, my versa was working again. That lasted about 3 days and it started not working again. I've given up on versa. I will need to find a way to delete my post.
Thanks for your help!
Best Answer06-17-2019 02:31
06-17-2019 02:31
Same here
Best Answer06-17-2019 11:28
06-17-2019 11:28
