05-02-2018 09:24 - last edited on 05-04-2018 09:14 by AlejandraFitbit
How do I factory reset my Versa? Wipe it off.
12-14-2018 01:57
12-14-2018 01:57
If I factory reset does that delete all info as I find versa far too large for my wrist & I want to sell it. I also asked fit bit app to to Forget this device. Do I need to do anything else? Thank you
12-14-2018 01:59
12-14-2018 01:59
Did you just do a factory reset to delete yr data & account from the versa before taking it back. Ta
12-18-2018 19:51
12-18-2018 19:51
I have a black screen and can't reset it
12-18-2018 20:05
12-18-2018 20:05
@Mamoune69 Have you tried plugging your tracker for charging for several hours (4 or more), then performing 3-button factory reset?
You may need to attempt the reset a few times to find the optimal times. Trying holding the buttons longer, as long as it's needed for the vibration to appear.
If you're successful with factory reset, please remember to remove Versa from your Fitbit account (in your Fitbit mobile app) and Paired Devices list in your phone Bluetooth settings as you will have to set it up again (add as a new device).
12-18-2018 20:18
12-18-2018 20:18
12-18-2018 20:22
12-18-2018 20:22
@Mamoune69 when was the last sync?
12-23-2018 22:50
12-23-2018 22:50
@Mamoune69 Merry Christmas! Did you manage to breathe new life into your Versa?
12-24-2018 06:45
12-24-2018 06:45
12-24-2018 06:46
12-24-2018 06:46
No nothing it just vibrate when I tried to reset it
12-24-2018 18:17
12-24-2018 18:17
This is the saddest ever Xmas gift from Fitbit.
My Versa died too. It will not respond to back+left or all 3 buttons after hours of charging,
Years ago I've left Fitbit for good after exchanging 3 Charge HR in two years due to numerous issues.
Where was my long term memory? Why did I even hope something has changed?
12-25-2018 10:20
12-25-2018 10:20
I had a problem connecting to my Samsung S4. Finally found that I had to unpair two other Bluetooth devices even though they were not connected to the phone nor were they anywhere near the Versa. The other two devices are actually miles away but the app doesn't seem to like multiple devices in the list. Once I unpaired the old devices, setup went quickly. I hope this helps. Fitbit should be ashamed of themselves for this mess.
12-26-2018 22:30
12-26-2018 22:30
Same on the versa..gets to phase two of the setup process and then shuts down back to the beginning. Tried all the hard boot restarts. This is ridiculously long on the set up process.
12-27-2018 17:37
12-27-2018 17:37
@Mamoune69 I'm afraid this might be a hardware issue. Please contact Customer Support as you might need a replacement.
12-27-2018 20:16
12-27-2018 20:16
The issue with mine is definitely firmware. I'm shocked at how sophomoric the firmware on this thing.
12-29-2018 10:22
12-29-2018 10:22
Just got a Versa. Even more difficult to set up than the Blaze. Even 2 hours on Fitbit chat I could not make the thing download firmware. A couple of points common to this thread:
1) On initial set-up, nothing will make the F/B vibrate indicating that it has done a factory reset. I tried every combination of buttons. Plus of course, you can't press the buttons if the Versa is in the dock. I'm guessing that on initial set-up, you're pretty much stuck at factory configuration anyhow.
2) I can get the Versa to pair with my Samsung S7, and connect to my wireless network, but it gets stuck when trying to actually do a download.Eventually it all times out.
3) Tried the usual reset, reinstall, re-pair, reconnect dance that is all too familiar with Fitbit devices, all with customer support on-line but with no luck.
Best Fitbit could suggest is to process RMA or return Versa to store.
Fitbit engineering, if you read these reviews, please address the serious QA and usability issues with Versa. Seems like this is not the only device that simply does not work. Also need to address ways a user can monitor the whole setup process.
I have not been able to set-up any Fitbit device without resorting to hours of chat or phone support.
12-29-2018 12:06
12-29-2018 12:06
@FB_Versa_V_Bad Do you have any other trackers on your account? If yes, remove them before setting up Versa? Do you have any other Bluetooth devices paired with your phone? Unpair them, and reboot your phone. You can add them later. Reboot your Versa by pressing and holding the left and bottom right buttons until Fitbit logo flashes. Place Versa in charging dock. Make sure both devices involved are on strong WIFI network and very near your router. A tip, try different wifi (friend's place?) or setting up via Bluetooth tho it will take hours. Alternatively, you can attempt setting up (adding Versa as a new device to your Fitbit account) using other device like borrowed iPhone etc.
12-29-2018 12:58
12-29-2018 12:58
i found this post long time ago and wanted to share with you. How to reset Versa
Now, after setting up your Versa, it's possible you will need to perform an update. Before you begin the firmware update, make sure your watch is plugged into the charger and in range of your Wi-Fi network during the update. For best results, use your home or work Wi-Fi network. If you've never connected your watch to WiFi, see How do I connect my Fitbit watch to Wi-Fi?. If your Versa is having trouble updating with WiFi, please try the following:
If the update fails, restart your mobile device and try to update again. If your Versa can't update over WiFi follow the on-screen instructions in the Fitbit app to update your watch over Bluetooth instead. Note that firmware updates over Bluetooth may take significantly longer to complete. If the Versa is having trouble updating through Bluetooth try the following:
I hope this can be helpful, give it a try and keep me posted in case you need anything else.
12-29-2018 13:31
12-29-2018 13:31
Hi @ikoIko
That's the same thing Moderator @MarcoGFitbit posted in this thread back in September. It's Post #42 on page 3.
Did you have a problem with your Fitbit? You can also find information on this article - click to go there.
12-30-2018 21:08
12-30-2018 21:08
how do I do a factory reset on versa
12-30-2018 22:25
12-30-2018 22:25
Hi @Osamu71
Factory reset your Fitbit Charge 3, Fitbit Ionic, or Fitbit Versa to erase apps and all personal data from the device, including credit or debit cards you added (on devices that support Fitbit Pay). If you want to give your device to another person or wish to return it for a refund, first complete a factory reset:
On your device, open the Settings app > About > Factory Reset or Clear User Data.
