05-02-2018
09:24
09:14
AlejandraFitbit
05-02-2018
09:24
09:14
AlejandraFitbit
How do I factory reset my Versa? Wipe it off.
08-23-2019 06:59
08-23-2019 06:59
Best Answer08-23-2019 16:47
08-23-2019 16:47
Best Answer08-23-2019 17:38
08-23-2019 17:38
Best Answer08-29-2019 03:26
08-29-2019 03:26
Hi my Fitbit has literally died. Stopped working all of a sudden!! How can I resolve this I have tried holding the buttons blah blah, nothing is working. Only had 12months!!!!
Best Answer08-29-2019 04:19
08-29-2019 04:19
I had to contact the fitbit company through email explained what was going on, they gave me a an address to mail my watch to and then they sent me a new one.
Best Answer08-30-2019 15:16
08-30-2019 15:16
I went to settings and did a factory reset. How long dies it take? Its been a while
Best Answer09-01-2019 00:02
09-01-2019 00:02
Best Answer09-01-2019 08:01
09-01-2019 08:01
Best Answer09-01-2019 14:10
09-01-2019 14:10
Same here!
Best Answer09-25-2019 15:00
09-25-2019 15:00
Did everything and now my Fitbit says Data not cleared sync & try again
Best Answer10-02-2019 19:28
10-02-2019 19:28
Can you help me do a factory reset IF THE SCREEN IS BLACK AND NOT RESPONDING?!
Best Answer10-02-2019 20:51
10-02-2019 20:51
Best Answer11-02-2019 19:12
11-02-2019 19:12
If followed the instructions without the versa in the charging cradle and it worked for me, my touch screen was unresponsive but once I did the 3 button reset I got the vibration and hey presto the screen suddenly works..!!
thanks
Best Answer11-18-2019 17:07
11-18-2019 17:07
Same here, I can't get past this as well. My fibit time was off by an hour and a half , but I reset it when it would not connect. Now nothing can't redownload software and doesn't connect.
Best Answer12-11-2019 12:09
12-11-2019 12:09
Best Answer12-13-2019 00:16
12-13-2019 00:16
Well after the reset my Fitbit completely died. I’m going back to the retailer apparently Fitbit has a 2 year warranty, I’ve no idea how you call Fitbit especially if you live in Australia, just go back to where you purchased it.
Best Answer12-13-2019 13:56
12-13-2019 13:56
Hi, any chance you know how to un reset it?? Please answer i really need to know
Best Answer12-14-2019 17:54
12-14-2019 17:54
ive no idea. I just went back to where I purchased the Fitbit and they replaced it and in the process I’ve been able to get the new versa 2 which hopefully will last longer than 14 months.
Best Answer12-15-2019 09:05
12-15-2019 09:05
Best Answer12-15-2019 12:04
12-15-2019 12:04
