05-23-2018
18:06
18:33
EdsonFitbit
05-23-2018
18:06
18:33
EdsonFitbit
Hi,
while changing my straps for the watch, I seem to have accidentally shifted around my stats, and now the recent exercise bar is on the top, before the battery and date bar. I can't seem to shift it back down. Is there anyway to do it? The other stats are able to be rearranged at the bottom, but not the one which has been rearranged accidentally (the recent activities bar)
Thanks!
Moderator edit: added label
05-23-2018 18:35
05-23-2018 18:35
If you tap and hold until it toggles, then you can move the tiles around.
05-23-2018 19:56
05-23-2018 19:56
I tried, but it doesn't work. Like that particular one is ABOVE the 'top bar' (the batt% and the date), which separates it from the other stats. Also, I've tried swiping down with the 'recent activities' bar on the top and it freezes, but it works fine if my top bar is in view (how it suppose to be). I don't know if it makes sense to you, but it might be a bug
05-23-2018 20:11
05-23-2018 20:11
Oh ok. Sorry I couldn’t help you. Maybe try restarting it if you haven’t tried that yet.
05-23-2018 20:32
05-23-2018 20:32
No worries, thanks for your help! Restarting didn't change anything, sadly.... Hopefully it's just a bug
11-30-2018 01:47
11-30-2018 01:47
This has happened to me too, is there any answers to fixing this????
12-02-2018 16:03
12-02-2018 16:03
@Grandpasmurf hey, i went to exchange mine since it was still covered under warranty, you might want to do that too (also, my battery was draining faster that usual, usually lasting about a day after a full charge)
