How do I see my steps per hour on the Versa 3?
ANSWERED
Firstly thank you for helping on vibrations
now how do I see how many steps I have done in the hour
1 BEST ANSWER
Accepted Solutions
Hi there, @Mark1669. Welcome to the Community Forums. I'm glad to hear that the issue with the vibration motor has been solved. 🙂
Regarding to your inquiry, please follow @LZeeW suggestions. You can find more information here What are the reminders I see on my Fitbit device?
Hope that helps.
3 REPLIES 3
@Mark1669   I looked at your profile and can see that you are a long time Fitbit user, with experience with other devices.  The Versa 3 has widgets you can see when you swipe up in the clock face.  Swipe up and look for the Advanced Stats widget.  Toggle it to on and add Hourly Activity.  You can also check on your Hourly Activity by swiping to the left, then tapping on your Today app and scrolling.  The widget is easier.
Laurie | Maryland
Hope that helps.
Is there any way I can consult my watch or my app within an hour to track how many steps I have taken that hour? Also when the reminder arrives at 10 minutes to the hour and says I need 235 steps – for example – is it possible to check five minutes before the hour how many steps to go before I hit 250? I was able to do this with a Fitbit versa two but cannot find this function on the versa three.
Thanks
