09-19-2023
06:05
04:51
09-19-2023
06:05
04:51
I just got a versa 3 trying to get use to it and had volume control on screen but now it's gone and want to put it back on the screen any help on this subject?thanks!
09-19-2023 09:48 - edited 09-19-2023 09:49
Hi @Gonnaretire - volume control is sometimes tiny and it depends what you are using it for. If it is for calls it may not be available unless you are in a call
Here are some examples, note the volume [speaker] is only available once in a call, it will be the same for music.
The volume levels needs to be set each time for calls.
