04-22-2022
00:29
20:02
04-22-2022
00:29
20:02
I am unable to see watsapp notification on versa 3,,how to set up?
04-22-2022 03:53 - edited 12-31-2023 04:29
Hi there, @DRNaresh. Welcome to the Community Forums.
Since you're setting up WhatsApp notification, you'll need to receive a message from the app desired in order for your app to show it as option in your Fitbit notification's section. For example, tell her to send you a WhatsApp, then check your Fitbit app and you'll see that WhatsApp is already an option to be selected. Then do the same with her so she can set up WhatsApp notifications on the watch.
Nevertheless, please note that you can choose 1 app per category. The most common apps for these features are:
However, for "Text Messages" section you can only select your primary text messaging app (that can be WhatsApp, your phone's default Message app or any other). Nevertheless, in "App Notifications" section you can select more apps, for example if you decided that for your primary text messaging app you want it to be WhatsApp, in App Notifications you can enable Messages app.
For more information, see How do I get notifications from my phone on my Fitbit device?
Hope this helps.
Best Answer04-22-2022 03:53 - edited 12-31-2023 04:29
Hope this helps.
