How do I set up my Versa for actual diving
I have used this in the Red Sea very recently and it is certainly waterproof but not sure how to set it up for actual diving... can anyone help please? Thanks in advance
Moderator edit: added label
1 REPLY 1
The Versa is only water resistant to 50m/5atm (Swimming/shallow submersion). It's not recommended to dive with a watch rating of this depth, as the device is only tested to static pressure equivalent to this depth. So unless you don't plan to move the device around, the depth it will be able to withstand will be a lot less. Obviously it's entirely up to you how you use your device, but you won't find any options for tracking said activities.
Community Council Member
Nathan | UK
Looking to get more sleep? Join the conversation on the Sleep better forum.
