08-06-2020
16:22
06:23
08-06-2020
16:22
06:23
I just got my versa 2, and I am trying to set it to receive notification from apps such as Facebook, Instagram, and WhatsApp; however, when I go into the Fitbit app on my pixel 3 under notifications none of these apps are showing up. How do I fix this? Thanks!
08-06-2020 17:38
08-06-2020 17:38
On the phone app go to the Versa 2 options and then tap on Notifications. On the next screen tap on App Notifications. This should bring you to a list of all the apps on your phone with a check box. Check off the ones you want notifications sent to your V2. Hope this helps.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
