12-29-2019
21:32
07:25
AlejandraFitbit
12-29-2019
21:32
07:25
AlejandraFitbit
I have the Versa Lite watch, how do I sync my weather app with it?
01-01-2020 07:26
01-01-2020 07:26
Welcome to the Forums, @Kristi_Smith.
Regarding your inquiry, to set up the Weather app:
If the weather doesn't update, check the following settings:
If you change locations, sync your device to see your new location in the Weather app.
To change the units used for the temperature in the Weather app:
Let me know if you need anything else. 🙂
05-24-2021 12:24
05-24-2021 12:24
I tried step one, and never saw APP to select it. I have a Fit Bit Versa Lite Limited. I have no clue how to set the weather on the app itself. I see the icon on the Fit Bit and it tells me to go set it up in the app. I am so lost.
07-18-2022 01:30
07-18-2022 01:30
Me too - Fitbit Versa Lite - no weather app to see.
07-18-2022 10:19
07-18-2022 10:19
@JiffyPixShar- this may help How to change temperature - for Weather, Centigrade - Fahrenheit, Versa 2, Versa Lite, Versa
