08-23-2022
04:37
17:20
08-23-2022
04:37
17:20
Last month i started with crossfit and i don't know with exercise program matches the best with this sport (looking at the calorie burns) because there isn't a crossfit module. I hope somebody have the answer, so my activity can be measured correctly.
08-23-2022 05:02 - edited 07-14-2023 03:55
Hi there, @Ingeh25. Welcome to the Community Forums. Thanks for sharing the details about the inquiry with your Versa 3.
Please note when a specific exercise is not available within the exercises we offer, we suggest to use "Workout" (which is a generic catch-all for other types of exercise). Once you finish the activity, you can rename the activity to desired exercise/activity. Please note that the amount of calories burned vary from the exercise you're performing and due to the heart rate tracked by your Versa 3.
Note that the information to enter will change depending on the nature of the exercise. To give you an example, if you change from "Workout" to "CrossFit", it won't remove the steps but will add calories as the main stat to be displayed, this happen depending of the activity you are categorizing. However, your the data already tracked will be still counted for your daily totals.
For more information about how to do so, see How do I add, edit, or delete Fitbit data and activities?
