07-13-2020
16:57
05:42
07-13-2020
16:57
05:42
I’m not supposed to wear my watch while playing. So what should I do because I’m not completing my daily goals because of this. I play hockey year round. I need help if anyone has any suggestions please tell me.
07-14-2020 05:38 - edited 09-30-2023 07:59
Hi there @Slapshot2520, welcome to the Community Forums. Thanks for the details provided, I'll be glad to help you with your inquiry about tracking Ice Hockey with your Versa 2.
If you cannot wear your Versa 2, you forgot to wear it or you want to record an activity that isn't detected automatically, manually log the exercise in the Fitbit app. For more information, see How do I add, edit, or delete Fitbit data and activities?
On the other hand, note that when a specific exercise is not available within the exercises we offer, we suggest to use "Workout". Once you finish your play, you can rename the activity to Ice Hockey.
Please note that when renaming the activity from Workout to Hockey, the information to enter will change depending on the nature of the exercise. To give you an example if you change a workout to Run, it wont remove the calories but will add distance and this happen depending of the activity you are categorizing.
Best Answer07-14-2020 05:38 - edited 09-30-2023 07:59
