08-04-2022
09:09
10:32
08-04-2022
09:09
10:32
What exercise do you use to record dance like Zumba and werq fitness. I did walking but i know their is something better
08-04-2022 10:34 - edited 06-28-2023 10:17
Hi there, @Yeya127. Welcome to the Community Forums.
When a specific exercise is not available within the exercises we offer, we suggest to use "Workout" (which is a generic catch-all for other types of exercise). Once you finish the activity, you can rename the activity to desired exercise/activity. Please note that the amount of calories burned vary from the exercise you're performing and due to the heart rate tracked by your Versa 2.
Note that the information to enter will change depending on the nature of the exercise. To give you an example, if you change from "Workout" to "Run", it won't remove the calories but will add distance as the main stat to be displayed, this happen depending of the activity you are categorizing. However, your the data already tracked will be still counted for your daily totals.
For more information about how to do so, see How do I add, edit, or delete Fitbit data and activities?
