04-25-2018
18:33
04:39
YojanaFitbit
04-25-2018
18:33
04:39
YojanaFitbit
How do I transfer Music to my Fitbit? I watched a video on YouTube which makes it look easy except for the part I am suppose to click on the tiny watch icon in the upper right corner of my dashboard. I don't have that small watch icon so now what?
05-26-2018 06:14
05-26-2018 06:14
Thanks for your help. I have not yet tried this but plan to tonight.
Best Answer05-26-2018 08:10
05-26-2018 08:10
how can i download music into my watch?
Best Answer05-26-2018 08:12
05-26-2018 08:12
read message 56
it will tell you how.. it worked for me
Versa123 has posted
05-26-2018 08:24
05-26-2018 08:24
how can i read the messages am new to this sorry?
Best Answer05-26-2018 08:26
05-26-2018 08:26
i am posting it here for you
05-22-2018 14:22
Hello. I finally figured it out! So if you go on your computer and download the Fitbit Connect app, you can plug your Versa charger into the computer. Then, plug your Versa into it and go to the Music app on the Versa. On the computer, click “Manage My Music” and click “Transfer Music” on the Versa. It does take quite a while; five minutes at most. Finally, it connects and will show all of your iTunes folders to transfer. You then click the check marks for what folders you want to transfer and click “Upload”. Set aside about 15 minutes for this, depending on how much music you wish to transfer. Hope I could help!
as a reference.. look at your post.. under your name.. it will say post 64 out of 64
so i if say post 56.. then you have to go to page before.. and look for the post
and we all started somewhere 😄
no need to appologize
05-26-2018 08:26
05-28-2018 23:59
05-28-2018 23:59
It is also dependent on the size and amount of songs. I transferred 20 songs in 15 minutes. But if you are trying to sync 150 - 200 songs then it will take a while.
Best Answer06-04-2018 22:15
06-04-2018 22:15
I’m having exactly the same issue with my new Versa! I am sooo frustrated with all the problems it’s giving me that I’m ready to return the Versa and keep my charge 2!
07-11-2018 19:32
07-11-2018 19:32
I have the same issue.
I think it s because versa is connecting with my phone.
So before i connect with my laptop , I go to Watch's settings, about, and shutdown my watch.
than connect with computer.
07-23-2018 15:19
07-23-2018 15:19
It's July 23 same issue, I just upgraded from the Charge2, having the option of downloading music is important. Very disappointed in Fitbit!!
Best Answer07-23-2018 15:54
07-23-2018 15:54
07-28-2018 20:21
07-28-2018 20:21
I am not sure why it cant be transferred via USB since you need to be charging anyway. This is quite ridiculous to rely on your WiFi to transfer.
Best Answer07-28-2018 21:01
07-28-2018 21:01
Thank you!! I gave up and returned my Versa. Went back to my loyal Charge HR 2!!!
Best Answer08-30-2018 14:56
08-30-2018 14:56
Myself, as well. This is the only reason I bought the versa. I liked that I wouldn't have to take my phone as well to listen to music.
Best Answer11-01-2018 02:00
11-01-2018 02:00
Use Musconv tool to sync playlist from one stream to another stream. Find More details at <a htref="www.musconv.com">MUSCONV</a>
Best Answer11-01-2018 02:03
11-01-2018 02:03
Try MUSCONV Tool to import playlist from one music stream to other. It's really nice tool which i personally used.
12-16-2018 18:11
12-16-2018 18:11
I had the exact same problem, after about an hour I noticed the watch icon in the upper LEFT of my screen lol.
12-24-2018 23:54
12-24-2018 23:54
This was very helpful. I plugged my versa charger into my computer's usb port, I'm not sure if that helped, but it worked.
Best Answer12-26-2018 21:15
12-26-2018 21:15
I just downloaded 17 plus hours of music onto my Versa using windows 7 and the fitbit connect desktop app no problems. Does take awhile to do so however.
12-26-2018 21:18
12-26-2018 21:18
I just downloaded 17 plus hours of music onto my Versa using windows 7 and the Fit bit connect desktop app no problems. Does take awhile to do so however.
