05-03-2018
19:00
08:32
AlejandraFitbit
05-03-2018
19:00
08:32
AlejandraFitbit
Just received my Versa today. However, I would really like to put music on my device, but all I am seeing is that it has to be done via WiFi. All of my music is on a desktop computer that is hardwired into the router. Is there no possible way to transfer music with this scenario?
05-04-2018 08:36
05-04-2018 08:36
A warm welcome to the Community @ventura9496.
Regarding your inquiry, to download playlists to your watch, you need a computer with a Wi-Fi connection and the free Fitbit desktop app. Choose between the following options:
* Windows 10 PC and the Fitbit app
* Mac or Windows 7/8 PC and the Fitbit Connect app
For more information, I recommend taking a look at the How do I listen to music and podcasts on my Fitbit watch? article, where you will be able to find step by step instructions on how to do this.
Let me know how it goes. ![]()
Best Answer05-04-2018 08:36
05-04-2018 08:36
Best Answer05-04-2018 08:47
05-04-2018 08:47
You can add Wi-Fi capability to your desktop by purchasing an external adapter that plugs into an un-used USB port on your computer. Just be sure that your desktop is in range of your router so a good strong Wi-Fi signal is available. USB adapters cost around $15-$25 and are generally pretty reliable...here's an example: USB Wi-Fi adapter
06-01-2018 23:15
06-01-2018 23:15
the solution is for only the iconic and i have the versa its brand new i cant do anything to it for both Bluetooth earphones and music and sadly its making me angry can someone help me who has a versa
06-02-2018 05:32
06-02-2018 05:32
Agree with Jessica. None of this works with Versa and continues to say that Versa is mobile only.
06-02-2018 15:19
06-02-2018 15:19
06-09-2018 03:11
06-09-2018 03:11
No, you just need any bluetooth earphones. I've already paired my Trainer earphones to it.
Best Answer09-16-2018 01:52
09-16-2018 01:52
After I download the fitbit connect, it cannot connect to my versa.
No response at all.
Best Answer03-24-2019 08:45
03-24-2019 08:45
I have downloaded music to my Tablet but cannot get it to transfer to my Versa? Very frustrating.
03-25-2019 17:28
03-25-2019 17:28
Best Answer03-26-2019 01:24
03-26-2019 01:24
I'm trying to transfer my music on my Mac laptop, Iv got Fitbit on my laptop, I have got a playlist and Im adding music to it but it says DRM-encrypted file. Cant transfer,Im transferring it form my music for my iTunes
Best Answer04-01-2019 23:29
04-01-2019 23:29
You may try Mobikin data transfer software to help you transfer music to Versa.
It can connect two devices and allows user to transfer files easily.
Best Answer04-02-2019 06:32
04-02-2019 06:32
