10-18-2022
15:11
17:02
10-18-2022
15:11
17:02
Recently, my Versa 3 will always display the clock, even when at rest. This is draining the battery twice as fast as before. I have downloaded several versions of clock faces trying in vain to find one that will "time out". How can I get my clock to work properly, like it used to?
10-18-2022 16:46 - edited 01-29-2025 07:44
Hi there, @Kaebean. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3. I understand where your concern is coming from.
Please check if your Versa 3 is not set on "Always-On" as this feature will only show you the time on the main screen all the time, unless you press the button of your watch to see other features and stats. If Always-On is enable, to exit this mode, turn your wrist toward you, press the button, or double-tap the display. For more information, see How do I see the time on my Fitbit device?
Hope that helps.
Hope that helps.
10-19-2022 08:41
10-19-2022 08:41
Thank you, that was helpful. I didn't know there was that feature and it took me awhile to find it to turn it off.
10-19-2022 10:44 - edited 06-27-2023 10:01
@Kaebean You're very welcome! I'm glad to hear the steps suggested did the trick. 🙂
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
