10-28-2018 00:55
10-28-2018 00:55
I recently set a PIN number, as I was thinking about using the Pay function, I now have to use the Pin everytime I look at it, how do I disable the pin function?
10-29-2018 13:17
10-29-2018 13:17
Hey @Stuggs, let me give you a warm welcome to the Community! Do you want to disable the device lock option at all? Or do you want to change the frequency you enter your pin? In the meantime, let me explain to you that you must enter your PIN code at least once a day. Your watch prompts you to enter your PIN code based on your device lock setting:
Note that your card issuer may require you to re-enter your PIN code to authorize a payment.
To change the device lock setting:
Hope this helps!
