How do i update the weather on my Versa?
How do i update the weather on my Fitbit Versa watch?
1 REPLY 1
Welcome to the Fitbit Community @HTJ839. I'll be happy to assist you with your weather on your Versa inquiry.
To set up the Weather app:
  1. In the Fitbit app, tap the Today tab User-added image > your profile picture > your device image > Apps.
  2. Tap the gear icon User-added image next to Weather. You may need to swipe up to find the app.
  3. By default, the Weather app shows your current location, which can't be deleted. Add up to 2 additional locations you want to see in the Weather app.
  4. Sync your device with the Fitbit app. It can take a few minutes to see the updated list of locations on your device.
If the weather doesn't update, check the following settings:
If you change locations, sync your device to see your new location in the Weather app.
To change the units used for the temperature in the Weather app:
  3. In the Temperature Unit section, tap Units and choose the unit you want to use.
  4. Sync your device and then open the Weather app User-added image​ on your device to see the updated units.
Please let me know if you have more questions.
