01-14-2021 08:52
01-14-2021 08:52
Hi
I am new to FitBit, I am expecting to get a FitBit Versa 2 delivered with a week or so
So I need to know after you use outside
How do you clean it and disinfect it against covid-19
Can you just watch it in the sink, if so what type of cleaner can be used
And how often can you clean it, I mean if you clean multiple times per day, is this bad, or ok
Thanks
Ali
01-14-2021 08:56
01-14-2021 08:56
Hi @shishini you can't wash a Fitbit like you would a dish in the sink. Here are the instruction - click to read. I use rubbing alcohol on the band and quickly wipe it on the underside. I clean it after charging and before putting it back on my wrist. I've been doing this for years and it's worked well.
01-14-2021 09:05
01-14-2021 09:05
So put some alcohol (70%) on a tissue and quickly wipe the watch, did I understand correctly 🙂
Is it ok to wipe the watch face and sides with the alcohol? or just the underside
Note my concern is disinfecting
Thanks
01-14-2021 10:46
01-14-2021 10:46
@shishini I wipe it gently all over with the alcohol and then I dry it. I'm not sure if it's 100% disinfected, but it's kept me safe all these months. Often I wear a long sleeve shirt, so the Fitbit is covered anyway.
