01-26-2021 16:45 - last edited on 12-18-2022 20:47 by MatthewFitbit
Do I have to put my versa 3 in swim mode when showering to make it water proof? Or is it waterproof all the time?
01-27-2021 22:18
01-27-2021 22:18
The swim setting is for it to measure your swimming activity.
If you are not going to swim there is no need to choose swim as an exercise.
It doesn't change the watch characteristics regarding it being waterproof or water resistant.
Hope that helps.
01-26-2021 22:46
01-27-2021 00:40
01-27-2021 00:40
@Guy_ Leah Aly these watched are only water resistant, their is no legal definition for waterproof, even when referring to a rain coat.
01-27-2021 02:58 - edited 03-28-2024 05:28
Hi there @AlexC04, welcome to the Community Forums.
As already mentioned by @Guy_ and @Rich_Laue, most Fitbit devices are water-resistant to 50 meters. They're designed to be swimproof and stand up to even the sweatiest of workouts.
Even though it may be ok to shower with our water-resistant devices, not doing so reduces the potential for exposure to soaps, shampoos, and conditioners, which can cause long-term damage to your device and may cause skin irritation. We also don’t recommend wearing any of our devices in a hot tub or sauna.
Water resistance may diminish over time and can be negatively impacted by any of the following:
Let me know if you have any questions present.
01-27-2021 13:53
01-27-2021 13:53
01-27-2021 22:18
01-27-2021 22:18
Hope that helps.
01-28-2021 06:21
01-28-2021 06:21
02-01-2021 19:16
02-01-2021 19:16
Unlike the inspire 2, your watch does not have a water mode to disable the touch screen.
08-26-2021 16:45
08-26-2021 16:45
Are you recommending not to wear the versa3 Fitbit during Water aerobics classes??
08-27-2021 03:44
08-27-2021 03:44
@KarinAStewart - You can wear it, as its waterproof, however it has a very touch sensitive screen and it is possible functions may be initiated.
Best to try and see.
08-27-2021 07:06 - edited 01-05-2022 19:04
@KarinAStewart I'm not sure who you are asking.
Your tracker is an activity tracker and may be worn during water aerobics, you may want to use the workout mode that gives the option to rename the event after a sync.
@Guy_ leagaly there is no definition of the term " waterproof" when it comes to trqckers. Watches are water resistant to XX pounds of pressure. Which is the point at which failure may occur. In general showering is not recommended, however Fitbit disagrees.
01-05-2022 09:54
01-05-2022 09:54
Every time my fitbit versa 3 gets wet it goes to settings and vibrates.. What is the deal with that?
01-05-2022 19:57
01-06-2022 04:16
