06-29-2018
05:36
07:29
AlejandraFitbit
06-29-2018
05:36
07:29
AlejandraFitbit
So, if I am going swimming, how long can my Versa be in the water before being submerged in water?
07-01-2018
07:33
09:52
07-01-2018
07:33
09:52
Hey @1swat1, great to see you participating in the Community.
Regarding your inquiry, Fitbit Versa is swim-proof (up to 50 meters). For more information, take a look at the help article Can I swim or shower with my Fitbit device?.
Happy stepping. ![]()
11-10-2018 20:50
11-10-2018 20:50
Is that 50 meters deep? and how much time can the versa be in water?
Best Answer11-28-2018 01:15
11-28-2018 01:15
We know how deep it can go but how long can it be under the water for? Like time? An hour, a couple of hours?
07:53
09:52
11-28-2018
07:53
09:52
Hello @SunsetRunner, thanks for joining the Fitbit Community, it's great to have you on board. It's nice to see you too @Ajendas80, I hope you're having a great day. ![]()
Please note the Fitbit Versa is swim-proof and can be worn in the lake, the pool or the ocean for as long as you like, taking in consideration that it is resistant up to 50m underwater. With that said, it’s important to thoroughly dry your elastomer band and tracker and remove any debris from your device after wear in the water Take in consideration that non-elastomer accessories should not be worn in water. To minimize damage to your watch, avoid any direct contact of sunscreen or insect repellent sprays with your tracker or watch. Remove your tracker while applying these sprays.
I hope this resolves your inquiry, if there's anything else we can do for you, please feel free to reply.
06-14-2019 19:26
06-14-2019 19:26
A question was answer that a fitbit versa can me emerged for 50m, but how many hours can it be in water??
Best Answer07-14-2019 19:07
07-14-2019 19:07
It said that it could be underwater as long as you would like it to be just as long as it's not past the 50 meter mark.
Best Answer06-09-2022 01:03
06-09-2022 01:03
Yeah how long can the Versa2 last underneath the water surface
i don’t mean how much meters but HOW LONG
Best Answer07-16-2022 10:51
07-16-2022 10:51
We just found my son’s that he lost in the water 6 days ago, it was dead but is now charging.
Best Answer07-26-2022 23:33
07-26-2022 23:33
And what about now is it working? Did it charge? If it did how long did it take? Did it need to dry out?
Best Answer10-19-2022 15:36
10-19-2022 15:36
I accidentally didn't take mine off going into the ocean. Salt water worried me. Sure enough my ankle kept buzzing. Fitbit not working right. I tried drying it out that day but wouldn't stop buzzing until the battery finally died. I tried charging the next day it wouldn't.I put it up. I just took it out and it's working. It took a couple tries of charging and cleaning it completely with rubbing alcohol. Not sure if that is recommended, maybe not so don't take my advice.After that it is was working fine. So far still charging and keeping a charge. Mine is 4 years old.
Best Answer10-19-2022 15:49
10-19-2022 15:49
I’ve worn my 3+ year old Versa 2 in the water (pools and ocean) many times and never had an issue. I think the longest at one time was about an hour between swimming laps and for a water aerobics class. Ocean diving was more like 20 minutes at a time down to 80 feet.
I never was brave enough to push the button underwater though…
Best Answer01-16-2023 06:31
01-16-2023 06:31
So basically, indefinitely? I can drop it in the creek and find it 2 days later and it’ll work?
