04-21-2019
19:38
11:51
MarcoGFitbit
04-21-2019
19:38
11:51
MarcoGFitbit
How long until the Samsung S10 will be compatible with my Versa?
01-15-2020 16:51
01-15-2020 16:51
I also have a Samsung s10 and receive all notifications except texts. After receiving a lot of texts in a row, sometimes I will get a notification on my versa 2 that says "new messages" but won't show the context of any of the messages. I have went though every setting on my phone, the app, and my versa 2 and have went through every troubleshooting step imaginable. I tried resetting and reconnecting everything and still no change. If anyone has any advice, I'd love to hear new suggestions
Best Answer01-17-2020 06:30
01-17-2020 06:30
I am having the same issue with my versa 2 and my galaxy s10+. My daughter seems to think it depends on which clock face you are using. I changed mine, and then I started receiving text notifications.
Best Answer01-19-2020 12:07
01-19-2020 12:07
I have an S10+ and I'm using the Bitmoji clock face. Can you tell me what clock face you changed it to to make your text messages come through? I have gone through all the "permissions" and I just can't get my text messages or calls to come up on my Versa 2
Thank you
Best Answer01-19-2020 12:20
01-19-2020 12:20
Best Answer02-01-2020 20:47
02-01-2020 20:47
I'm in the same boat. I've been waiting a month but looking at this thread it looks like others have been waiting for 7 months! How long does it take to fix this issue!?! Doesn't make any sense!
Best Answer02-02-2020 08:56
02-02-2020 08:56
By the time they fix it and we get to use it our warranty will have expired and then something else will go wrong. I will never recommend purchasing this product
02-05-2020 07:24
02-05-2020 07:24
I went back to the original Versa 2 clock face. I called customer support about this issue and asked about different clock faces interfering with text messages. She told that they shouldn't.
Best Answer02-05-2020 09:27
02-05-2020 09:27
I have been trying to get the original clock face back too because others have said it helps, but for some reason I can't get it....
Best Answer02-05-2020 13:37
02-05-2020 13:37
I tried the clock face fix. No go. The only thing that works is the Google messaging app. Which is fine FOR NOW. But I'd really like to go back to using the one that came with the phone.
Best Answer02-05-2020 21:05
02-05-2020 21:05
Which messaging app did you download?
Best Answer02-06-2020 13:47
02-06-2020 13:47
Hey..Now its almost 1 year later. Any news when S10 will be compatible for the text messaging?!
Best Answer02-06-2020 13:49
02-06-2020 13:49
Does it works for you now?...feb 6th 2020, my. S10 and charge 3 wont conect fully..i cant get text notifications. You?
Best Answer02-06-2020 13:50
02-06-2020 13:50
Best Answer02-06-2020 14:05
02-06-2020 14:05
Best Answer02-06-2020 14:21
02-06-2020 14:21
Best Answer02-06-2020 14:25
02-06-2020 14:25
Best Answer02-06-2020 23:42
02-06-2020 23:42
Best Answer02-06-2020 23:43
02-06-2020 23:43
Best Answer02-06-2020 23:45
02-06-2020 23:45
Best Answer02-07-2020 03:42
02-07-2020 03:42
Another user mentioned changing your messaging app to Google messages. That DOES work at least for me.
