01-31-2020 12:17 - edited 01-31-2020 14:58
I have left my Fitbit versa charging in a locked room but have an alarm due to go off, I won’t be able to get in to switch it off for 2/3 days, how many times will the alarm snooze before turning off? Or will it continue until it is manually switched off?
Thanks
02-11-2020 16:13
02-11-2020 16:13
Welcome to the Fitbit Community @LaurenAnn149.
Thank you for your question about how many times an alarm will snooze.
When a silent alarm goes off, a vibration and a flash will repeat several times or until dismissed. If you don't dismiss an alarm, it repeats in 9 minutes a couple of times. Alarms won't go off if your watch has less than 8% battery
If the locked room where you forgot your Fitbit Versa is not that big, you can turn the alarm off from the app and try to sync. Instructions to delete or turn off an alarm, can be found on this article.
If you have any other question, please don't hesitate to contact us back at any time.
