02-26-2020
22:02
11:37
LizzyFitbit
02-26-2020
22:02
11:37
LizzyFitbit
How much voltage adapter is to be used with fitbit Versa 2 charger.
04-27-2020
12:28
08:11
04-27-2020
12:28
08:11
@Preetkalia Welcome to the Community. Sorry for the delay in my reply.
Let me help you with your inquiry. If you are talking about the electric adapter to use on the wall to charge a Versa 2 then it will depend on where you live and the standard use there. Usually it will range between 110 V to 240 V. When using a quality wall adapter it will use the appropriate voltage and feed the required power to the device you are plugging following the USB standard. The key here is that you need a quality charger one that follows the UL certification as explained here. If you check most wall adapters you will find something along these lines:
If you notice you will see a range of 100 to 240 volts and will provide an output at 5 volts of 1000 mA max although following the usb specification will only provide the amount the device requires.
Let me know how it goes.
