10-07-2018 21:43
10-07-2018 21:43
How can i add Zumba or aerobic on the preset shortcut? I know there's a default on aerobic, but i would like to be able to press start when i start the workout, not 10 min after it gets recognized.
10-08-2018 01:59
10-08-2018 01:59
You cant. But you could track it as Workout and then change the name in the app afterwards. That would work as the the Workout exercise is designed to be renamed to the specific activity you want. But you need to donit each time you do Zumba.
Helen | Western Australia
Best Answer10-08-2018 01:59
10-08-2018 01:59
Best Answer10-08-2018 14:36
10-08-2018 14:36
Hey @Melanie4kps, I hope you are doin' fine! Well, like @NellyG said, it is not possible to add Zumba as an exercise shortcut to start the activity on the Versa itself, however, by using SmartTrack (auto-recognized exercises) you can record it if it at least 10 minutes long and then rename it. Or you can manually log it on your Fitbit account. Just follow the instructions in this help article: How do I track exercise and activity with my Fitbit device?
Hope that helps! 😉
02-02-2020 09:20
02-02-2020 09:20
Hi and tx for your reply. But can u tell me specifically where i go to rename? App on phone, computer? I have looked everywhere and can't find the screen nor an edit button. I also want to add Aerobic shortcut to rename as Zumba and cant find that either! Pls help
