05-02-2018 07:55
05-02-2018 07:55
How to change farenheit to celcius on a Fitbit Versa?
05-02-2018 10:17
05-02-2018 10:17
@Tashlim wrote:How to change farenheit to celcius on a Fitbit Versa?
If you are using a 3rd party clock face that shows temp, there should be a setting that makes that change. Check your clock details. As far as the Fitbit itself is concerned, go to Fitbit.com dashboard and click on the gear icon at the upper right and then Settings. Scroll down to "Units" and change them to Metric.
03-06-2019 15:38
03-06-2019 15:38
In units there is no option for temperature. How do I set to °F in weather app?
03-06-2019 16:39
03-06-2019 16:39
Go to the Weather App in Settings and click on the Gear Icon and choose F.
03-06-2019 17:33
03-06-2019 17:33
Hi, click the watch icon in the dashboard of your Fitbit app on your device. You will see the page with the Clock and Apps tiles. Press the apps and scroll down into "My Apps" untill you find the weather app. Right next to it, you will see the settings icon. Press that and you will see the page with Temperature unit, press Unit and there you can change it form Celsius to Fahrenheit or v.v..
