How to change temperature - for Weather, Centigrade - Fahrenheit, Versa 2, Versa Lite, Versa
If you set the temperature in the Fitbit App [profile photo => App settings => Units => temperature] and you are still not getting the degrees in Fahrenheit or Centigrade as you have defined it, it is because the Weather app has its own settings.
To fix the temperature degrees for Weather:
 In the Fitbit App click
  • Profile photo
  • Device photo
  • Gallery (or Apps)
  • Scroll to Weather
  • Settings
  • Temperature unit
  • Set to desired value
Then sync the watch.
For weather showing directly on the clock face there may or may not be a clock face setting to change.
If it is still a problem,
  • remove cities in the weather list of cities setting
  • and use current location
  • and sync again.
for more information see How do I set up and troubleshoot apps on my Fitbit device?
7 REPLIES 7
Thank you! Was trying to figure out this out today. I mean it's so obvious that the weather app is under Gallery and uses completely different settings than your watch /s
Thanks for your help and support 🙂, It is now fixed
Yay!  That worked!!  Thanks so much for your help!!!
This isn't working for me.
Hi @SuzanneM. - where di dyou change the settings and did you remove cities and sync?
Every time I've tried changing it following Fitbits recommendations, nothing happens. The second I found your post about the gallery and those settings, it's immediately fixed. Why the hell is the "app" settings in gallery and why can't Fitbit just help if that's truly where you have to go 🤣
Got it with your instructions.   Thank you!
