How to change the temperature to display in Fahrenheit?
ANSWERED
On the weather app, my fitbit Versa is displaying the temperature in Celsius format. How do I change it to display in Fahrenheit? Thanks!
60 REPLIES 60
Your welcome, glad it worked for you.Sent from my T-Mobile 4G LTE Device
It has worked!  I hope it continues to do so.  Thanks.
Hello.  Glad I could help. My settings have remained in place.  Hope yours do too 🙂
Thanks so much. That was easy!
I have the Versa Lite, and don’t have a setting for “apps” or “ weather” but I have the weather app , which is displayed in F.
Perfect  worked great
I'm using the Charge 3. The weather app displays celcius. How do I GET TO "apps" on my  find my phone's fitbit app to find weather app to change to farhenheit?
thanks for the weather answer not to old to learn something new
Thank you very much.
Thank  you for your help.  You made it so quick and easy for someone that don't  deal much with new technology.
Thank you!Sent from my T-Mobile 4G LTE Device
Help ... mine too!
The problem cannot be resolved by changing your weather app. You have to go to your clock face app and change the settings in that app to Fahrenheit.
Didn’t work
Yup.  Mine keeps reverting back to Celsius.
Versa 3 was a tad different.  From the phone fitbit app:
Click on account (top left)
Click on your Versa 3
Click on Gallery (of all places), then click on apps.  I had to search for the weather app that was installed
Click on the weather app THEN go to settings. There you will find "Unit".
Hi @ScottinLFK - when you click on Gallery you only need scroll down to the Weather, it saves searching in Apps.
This didn't work for me. I changed in it the app to fahrenheit but it still shows Celsius.
Hi @Anieves990 -  here is the full method, see How to change temperature - for Weather, Centigrade - Fahrenheit, Versa 2, Versa Lite, Versa
