How to change weather units on Versa 3?
The temperature on my weather app is showing degrees Celsius, not Farenheit. How can I fix this
Moderator Edit: Clarified subject.
1 REPLY 1
Welcome to the Fitbit Community, @Lynda1948. I'll be happy to assist with your weather units inquiry.
To change the units used for the temperature in the Weather app:
  1. Open the Fitbit app and tap the Account icon > your device image.
  2. Tap Apps.
  3. Tap the gear icon next to Weather. You may need to scroll down to find the app.
  4. In the Temperature Unit section, tap Units and choose the unit you want to use.
  5. Sync your device and then open the Weather app on your device to see the updated units.
