01-16-2019
10:02
08:42
MarcoGFitbit
01-16-2019
10:02
08:42
MarcoGFitbit
I got a fitbit versa and bluetooth ear buds (FALWEDI) they have no volume control so when i hooked them up to my watch the music is blasting loud and i can't fix it. I would like to leave my phone home when i go jogging and listen to my music but i can't please help me...
Best Answer01-17-2019 08:47
01-17-2019 08:47
Hello @Ryanschaum60, have a warm welcome to the Fitbit Community. It's great to have you on board. ![]()
I appreciate your participation in the Forums and for sharing your experience with us. Please note that when you start playing music on your Versa, you have the option to control its volume with the plus (+) and minus (-) sign located to the right of the screen:
You can also press the buttons on the side to increase or decrease the volume while the music is playing.
I hopet his helps, if there's anything else we can do for you, please feel free to reply.
02-21-2019 12:41
02-21-2019 12:41
I also have this problem the + and - do not work . Is there anything i can do so these earphones work??
Best Answer03-28-2019 18:27
03-28-2019 18:27
Thanks!!!
Best Answer12-29-2019 19:18
12-29-2019 19:18
Paired my AirPods to my Versa 2 and volume is way too loud and can’t adjust. Is there a way to do this. What a waste.
12-29-2019 21:33
12-29-2019 21:33
I Have the same problem. Volumn controls are not working. No additional buttons on side. Please help...way to loud
01-19-2020 14:49
01-19-2020 14:49
I'm having the same issue. The music is too loud on my Airpods and those volume controls on the watch screen don't do anything. Help?
02-18-2020 18:18
02-18-2020 18:18
I cannot control music volume either. I upgraded to the Versa 2 specifically for the ability to be able to play music directly from my watch. The volume buttons are completely unresponsive and the music is so loud that the music feature is unusable. If this problem cannot be resolved, I am returning the watch.
06-27-2022 18:23
06-27-2022 18:23
I have this problem and it is more than 2 years after this message. So, over 2 years and no fix. Starting to think getting a Fitbit was a waste.
Best Answer06-27-2022 18:25
06-27-2022 18:25
Maybe worked in 2019, but not in 2022. Maybe one of the updates I had to get screwed this up. Good job, guess FitBit doesn't care that there stuff doesn't work.
