10-11-2024
14:54
12:02
10-11-2024
14:54
12:02
How to reset versa 2 to factory settings
10-11-2024 17:14
10-11-2024 20:00
10-11-2024 20:00
Hi @Buleah - there are a couple of things to be aware of before doing a factory reset.
It is a good idea to make a note of the names of any clocks or apps and any special watch or app settings you use before the factory reset or replacement if necessary.
Also if you live in the EEA you will only be able to reinstall only Fitbit clocks or apps.
