03-18-2020
11:48
04:08
DavideFitbit
03-18-2020
11:48
04:08
DavideFitbit
Hi!
How to get the GPS working when cellphone isnt unlocked?
How to get the heartfrequens working perfectly? I dont get the right puls when i am exercising.
03-18-2020 13:21
03-18-2020 13:21
@Janamsk What's your phone model? You need to make sure Fitbit service is running in the background and is not getting killed. If you're on OnePlus, Huawei, etc you may ran into some issues as they're known for aggressive background process management. Re your heart rate, why do you think you're not getting the right readings? What type of exercise are you performing and what's your HR? Perhaps you could attach some screenshots?
03-20-2020 09:16
03-20-2020 09:16
I have a samsung s10, i know my HR isnt accuratly shown as i am running it shows around 80. And i am quite certain its more than that.
03-20-2020 09:43
03-30-2020 08:16
03-30-2020 08:16
Hi! I loose bluetooth connection quiet a lot and i rebooted the tracker and the app.
Now my next problem is that steps and distans are not the same. Today I took 1770 steps and the tracker says 10,3 kilometres. What to do?
