04-04-2019
21:18
09:37
MarcoGFitbit
04-04-2019
21:18
09:37
MarcoGFitbit
This is a replacement for the one I bought not quite a year ago. The face of the watch is very dim compared to the older one. I have an apple phone. Does anyone know how I can brighten the face?
Thank You,
Miriam
12-11-2019 05:42
12-11-2019 05:42
12-11-2019 05:49 - last edited on 03-09-2020 16:09 by LiliyaFitbit
So how did you fix the sleep mode problem? Pressing on the small crescent moon had no effect.
12-11-2019 05:54
12-11-2019 05:54
That did it! Sleep mode off then the dim will ungray and you can change it. Still, what kind of a lousy company can't fix this?
12-12-2019 06:24
12-12-2019 06:24
Swipe to settings, then scroll down to sleep mode. It's in there. Took me a minute to find it. On my Versa, it's BRIGHTNESS, then SCREEN TIMEOUT, then SLEEP MODE.
12-12-2019 08:05
12-12-2019 08:05
12-12-2019 14:16
12-12-2019 14:16
Thank you! That was helpful
12-29-2019 16:06
12-29-2019 16:06
Hooray! Thank you for the tip! I took it off sleep mode which inadvertently I had somehow set (without the help of a two year old)
01-04-2020 12:29
01-04-2020 12:29
Mine is the same nothing works did you find a solution?
01-04-2020 14:34
01-04-2020 14:34
01-06-2020 20:33
01-06-2020 20:33
Thanks my problem was it was in sleep mode, as soon as turned it off it went bright . Yae
01-18-2020 12:49
01-18-2020 12:49
Thank you so much:)
01-19-2020 14:43
01-19-2020 14:43
THANK YOU! That totally worked. I thought my Versa was broken. Super easy fix!
01-19-2020 17:39
01-19-2020 17:39
01-20-2020 07:17
01-20-2020 07:17
When I go to settings and try to tap on brightness - nothing happens
01-20-2020 09:39
01-20-2020 09:39
01-20-2020 09:42
01-20-2020 09:42
02-05-2020 12:08
02-05-2020 12:08
In my settings when I go to change the screen brightness it is darker than the rest of the other things to change, I can’t even touch it to change ? I don’t understand
02-05-2020 15:05
02-05-2020 15:05
02-05-2020 15:24
02-05-2020 15:24
02-05-2020 15:27
02-05-2020 15:27
