04-04-2019
21:18
09:37
MarcoGFitbit
04-04-2019
21:18
09:37
MarcoGFitbit
This is a replacement for the one I bought not quite a year ago. The face of the watch is very dim compared to the older one. I have an apple phone. Does anyone know how I can brighten the face?
Thank You,
Miriam
06-01-2020 18:42
06-01-2020 18:42
Thank you. Yes, it was in sleep mode.
06-13-2020 16:42
06-13-2020 16:42
My Fitbit versa will not get bright. It is permanent on dim. No tapping on the brightness will change it Help
06-13-2020 17:26
06-13-2020 17:26
06-13-2020 17:54
06-13-2020 17:54
06-13-2020 18:06
06-13-2020 18:06
06-15-2020 15:24
06-15-2020 15:24
How do you get to settings?
06-15-2020 15:51
06-15-2020 15:51
06-15-2020 16:04
06-15-2020 16:04
06-16-2020 00:20
06-16-2020 00:20
06-21-2020 19:26
06-21-2020 19:26
Your explanation was a big help, thank you so much!
06-21-2020 19:46
06-21-2020 19:46
Thank you so much. I tried this several times and nothing happened. All of a sudden this time I saw the sun. I made it brighter. Thank you very much
06-22-2020 10:35
06-22-2020 10:35
I found the solution to the dim screen for me - it was via Quick Settings - I had inadvertantly set some settings via quick settings (which left my screen dim and the Brightness setting was inactivated). Quick
Settings might be the trick for correcting many undesired behaviors for your fitbit.
Quick Settings is accessed on my Versa Lite having the clock face view, then holding the button for a second or 2 brings up the Quick Settings menu. Good Luck!
07-30-2020 21:15
07-30-2020 21:15
This does not work. the brightness option is greyed out and unselectable. It is set to "dim" ad not changeable.
07-30-2020 21:19
07-30-2020 21:19
All I can hope for is that the deal with Google happens and they fire al the developers. Not one of them has even asked for data or to see the screen. If this were my product, I'd be asking for people to send in their broken units so I could better understand the bug.
07-31-2020 04:42
07-31-2020 04:42
07-31-2020 05:06
08-23-2020 14:49
08-23-2020 14:49
What is sleep mode grey? I am trying to change the brightness on my versa.
08-23-2020 15:34
08-23-2020 15:34
08-23-2020 15:53
08-23-2020 15:53
Awesome, thank you!
That did it!
Appreciate the help.🙂
08-23-2020 17:40 - last edited on 09-04-2020 19:58 by LiliyaFitbit
I tried this, the option to increase brightness was greyed out. As it
turns out the software was broken and a factory reset and re-loading solved
the issue.
