04-04-2019
21:18
09:37
MarcoGFitbit
04-04-2019
21:18
09:37
MarcoGFitbit
This is a replacement for the one I bought not quite a year ago. The face of the watch is very dim compared to the older one. I have an apple phone. Does anyone know how I can brighten the face?
Thank You,
Miriam
08-23-2020 20:41
08-23-2020 20:41
Best Answer09-04-2020 13:36
09-04-2020 13:36
Found the setting but can’t seem to change it...right swipe on the setting? Mine somehow reverted to dim & very hard to read outdoors m.
Best Answer09-04-2020 15:06
09-04-2020 15:06
16:00
08:16
DavideFitbit
09-04-2020
16:00
08:16
DavideFitbit
How do I get to the “moon”? When I am in settings see the sleep mode option - but no moon displayed??
Thank you! Have been searching for the sleep mode button to get brightness back!
09-04-2020
19:00
08:16
DavideFitbit
09-04-2020
19:00
08:16
DavideFitbit
You’re welcome!! It drove me crazy too until I figured it out.
Drag down on the face once or twice ... til you see paddles ... click on paddles... moon will come up
Sent from my iPhone
09-20-2020 22:50
09-20-2020 22:50
Nailed it!💪😁
Best Answer09-21-2020 12:41
09-21-2020 12:41
Thank you, JOverland. This solved my problem.
Best Answer09-22-2020 05:08
09-22-2020 05:08
That worked for me! Thank you! It would have taken me forever to discover that!
Best Answer01-26-2021 13:33
01-26-2021 13:33
Do you know how to brighten the screen when it is so dark, you can't see the words on the screen?
Best Answer01-26-2021 14:52 - last edited on 01-28-2021 18:50 by LiliyaFitbit
turn off the sleeping mode.
[image: Image result for live love laugh]
Best Answer02-10-2021 16:55
02-10-2021 16:55
My dim is stuck and so 8s sleep made. Just beyond aggravation
Best Answer02-10-2021 17:02
02-10-2021 17:02
That was the exact answer I was looking for, sleep mode didnt work under settings.thanks. Nd doesn't it seem like no one is understanding that people didnt accidentally put their watch in sleep mode the update must have done it
Best Answer09-16-2021 09:55
09-16-2021 09:55
Brilliant, thanks a bunch!! 👍🏻
Best Answer02-28-2022 22:28
02-28-2022 22:28
Unable to change thehe brightness key..Can you please suggest any other way
Best Answer02-28-2022 22:32
02-28-2022 22:32
The sleep mode is also not changing. What is this WiFi loading of Versa?
Best Answer02-28-2022 22:48
02-28-2022 22:48
Unable to get the crescent activated. Pl give more details
Best Answer08-30-2022 11:19
08-30-2022 11:19
I have the same problem. The brightness does not increase when I click on bright. I’ve restarted it several times and it’s still very dim and has lost about 10 minutes
Best Answer08-30-2022 11:20
08-30-2022 11:20
Mine too and restarting doesn’t help
Best Answer09-02-2022 10:06
09-02-2022 10:06
It worked! Thanks for the answer, I’m 71 and my vision isn’t what it used to be. I’m all set now,,,BTW I really love the Versa 2 with its larger screen!
Best Answer09-04-2022 10:39
09-04-2022 10:39
Hello,
I received my replacement fitbit last year...but the experience with it was way worse then the last one.since last week...the screen has become dull green and I cannt see anything in daylight.somebody help
