05-15-2018 17:49
05-15-2018 17:49
Let's take the "Walk" exercise as an example. I want to "Customize Stats" and then set the Top Stat, Middle Stat, and Bottom Stat choices which run the display while the Walk exercise is active. I can set these up as I want them, but the next time I start the exercise they are back to their defaults and my changes are lost. If I'm missing something obvious here my apologies in advance, and thank you.
05-15-2018 18:53
05-15-2018 18:53
@SunsetRunner wrote:Let's take the "Walk" exercise as an example. I want to "Customize Stats" and then set the Top Stat, Middle Stat, and Bottom Stat choices which run the display while the Walk exercise is active. I can set these up as I want them, but the next time I start the exercise they are back to their defaults and my changes are lost. If I'm missing something obvious here my apologies in advance, and thank you.
No, you are not missing anything. That is a current fault and will be cured with the next update.
09-14-2018 06:46
09-14-2018 06:46
Why had this not been fixed yet I'm currently having this issue on my ionic and it's very frustrating !
10-30-2018 21:51
10-30-2018 21:51
It's not a bug Its a feature.
This occurred in version 2 of the software. Fitbit has know of it and been promising a fix 'soon" for several months.
When is "soon"?
