How to search for / filter free click faces for Versa?
I just got my Versa and had it set up yesterday. After trying out 3-4 clock faces, I noticed that today most clock faces I wanted to try cost money.
I don’t want to waste my time clicking on paid clock faces but have no way of setting a filter for that. What is the best way to do this? I typed in “free clock faces” but that didn’t work, FYI.
 Thank you.
1 REPLY 1
Hi, AFAIK there is no way in filtering regarding Third Party Clock Faces. you will have to do a search untill you find a Face that fits your needs. Only problem is that some of these Faces can cause severe errors on your Versa cause they are either not compatible with the new FW version of outdated or whatever. My personal experience is that payed versions always work and never give problems, but that's up to you of course. Most of then cost only $1 or slightly more. If I may make a suggestion, have a look on the Faces made by Olbia Coding. Most of them are payed ones but worth every penny of it, certainly after a trial period of 30 hours. Good luck!!
