How to see Active Zone Minutes on dashboard?
I cant seem to get Active Zones to appear on my Dashboard. Any ideas? I have a Versa 2, so I assume it will work.
2 REPLIES 2
Hi @SeanMD. Welcome to the Community Forums.
Thanks for sharing that your Versa 2 is now tracking your active zone minutes and let me help you with your question. Just to confirm, do you refer to the Today screen of the Fitbit app? Or do you mean the fitbit.com dashboard? I'm asking this as currently the active zone minutes are available just on your watch and the Fitbit app on a mobile device. Assuming your referred to the Fitbit app, give a try to the following steps:
  1. On the Today tab of the Fitbit app, tap Edit at the upper right corner.
  2. Tap Add or on the "+" sign to add a tile. If you want to hide a stat, just tap the X icon.
  3. Then tap on Done to save the changes.
I'll look forward to your response.
@SeanMD -
In addition to what @LizzyFitbit mentioned there is a way to see time in zones on the Web Dashboard. You will have to "do the math" to get Active Zone Minute totals.
Add the "Activity and Stats" panel to the Web Dashboard if it is not already there. When you select Heart Rate at the "Daily" level you will get this:
Good luck and good to see you on the boards.
RETIRED Enterprise Computing / "IT Guy" - Southern California - Marine Staff Sergeant 1970-78
Apple Watch 6 - iPhone 8 (iOS 16.7.8) - FitBit app 4.20 - MacBook Air (macOS Catalina)
