11-01-2019
18:16
16:27
SilviaFitbit
11-01-2019
18:16
16:27
SilviaFitbit
I have a fitbit alta registered on my phone, laptop and tablet and now have bought a fitbit versa2. When I try to log into fitbit for the versa2 app I am being told I can;t use that email address or password because it is already being used. How can I download the versa2 app.
11-02-2019
16:30
08:50
11-02-2019
16:30
08:50
@Woeduck Welcome to the Community. Thanks for the details mentioned, I'm glad to hear that you bought a Versa 2.
Since you already have an account created, in this case you will need to set up your Versa 2 in the same account that you have your Alta. If you want to use both, check this article to learn more about it: Can I use more than one Fitbit device with the same account?
If you want to set up your Versa 2 using your Fitbit app do the following:
If you want to do the procedure using Fitbit Connect, follow these steps:
I'll be around if you have any additional questions.
Best Answer11-02-2019 16:33 - edited 11-02-2019 16:35
DELETED POST
Best Answer11-03-2019 20:11
11-03-2019 20:11
Thank you all for your replies. Tried a bit of all of them and managed to add it to the existing account. Cheers.
11-06-2019
07:34
08:50
11-06-2019
07:34
08:50
@Woeduck Thanks for getting back. I'm glad to hear that you managed to add your Versa 2 to the existing account.
Hope I can continue seeing you around 😀.
Best Answer01-08-2020 07:54
01-08-2020 07:54
trying to set up my new Versa 2 on existing account and I am following instructions to do that but when the screen pops up asking which fitbit tracker are you setting up ? it doesn't have Versa 2 icon to choose.
Best Answer01-08-2020 08:00
01-08-2020 08:00
Update your App to the latest version.
01-08-2020 18:01
01-08-2020 18:01
Hi Thanks for your reply. All good now. Done Thanks anyway. Cheers
Best Answer01-08-2020 18:02
01-08-2020 18:02
Hi, All done now. Thanks all the same. Cheers
Best Answer01-08-2020 18:04
01-08-2020 18:04
Hi, All done now. Thanks all the samw. Cheers
