01-13-2019 21:58
01-13-2019 21:58
I selected a new clock face to install but for some reason the installation keeps failing and it says try again later. However, it continues to keep trying to install, which is apparently blocking me from going back to my old clock face or installing a new one. When I press the left button it says “clock error” and tells me to go to the mobile app and install another clock. But when I do that it says it’s busy installing a clock and try again later. I have tried restarting the Fitbit without effect. (I just updated the OS - silly me to have tried two things in one night.). I need to stop the current clock installation but don’t know how to do it.
01-13-2019 22:10
01-13-2019 22:10
@leftcoastwalker normally if you open the app, tap on versa icon, go to clocks, it should ask you if you want to continue installation. Choose later. Then select a new clock and tap install. Can you sync without issues? The fact that the clockface is stuck during installation might be related to poor Bluetooth connectivity.
02-25-2019 06:49
02-25-2019 06:49
I hit later but it doesn't stop. Also want to delete the ones that don't complete.
02-25-2019 07:58
02-25-2019 07:58
having the exact same issue. 😞
02-25-2019 09:15
02-25-2019 09:15
Mine won't install because I don't want the free. Not it won't stop installing either.
02-25-2019 09:17
02-25-2019 09:17
I know why. I want it to stop so I can use the one I had or another one. Hitting later doesn't work
02-26-2019 12:02
02-26-2019 12:02
@WorkinT1961 @dwstolberg are your trackers syncing without issues? When was the last sync (open Fitbit mobile app, tap on the Versa icon, scroll down to the sync section)? Do you receive notifications without problems?
05-06-2019 09:23
05-06-2019 09:23
Is there a resolution to this problem yet? I just got a Versa and I have the exact problem. Went through all the suggestions listed but still cannot stop or delete the current installation.
@leftcoastwalker wrote:I selected a new clock face to install but for some reason the installation keeps failing and it says try again later. However, it continues to keep trying to install, which is apparently blocking me from going back to my old clock face or installing a new one. When I press the left button it says “clock error” and tells me to go to the mobile app and install another clock. But when I do that it says it’s busy installing a clock and try again later. I have tried restarting the Fitbit without effect. (I just updated the OS - silly me to have tried two things in one night.). I need to stop the current clock installation but don’t know how to do it.
08-18-2019 08:38
08-18-2019 08:38
Does FitBit every reply with answers? I have the same issue along with not being able to sync. I removed the tracker and added back and it recognized and sent a code to sync, but, will not sync. I also reset the tracker in the charger few times. Any ideas?
09-18-2019 15:21
09-18-2019 15:21
having the same issue and it is preventing the versa from synching
10-05-2019 21:48
10-05-2019 21:48
After some tries, it finally worked!! I clicked “later” and then chose a free one from fitbit and it worked 🙏
10-23-2019 20:30
10-23-2019 20:30
How to stop a clock face from install.
Best Answer12-05-2019 22:19 - edited 12-05-2019 23:17
My issue was selecting the clock face from the My Clock Faces screen. It was doing the later or continue thing, so I went to all clock faces and downloaded one I didn't have, and then from All Clock Faces I picked the one I wanted that I already had downloaded (instead of from My Clock Faces) and switched to it and it worked just fine
Edit-
I just tried to change it again and now I can't load any clock faces so idk.
12-07-2019 10:31
12-07-2019 10:31
Has anyone found a definitive answer yet? I know some people have tried downloading new watch faces and had sucess, but nothing has worked for me yet. I've tried restarting multiple times (both my Galaxy s10+ and my Versa 2), downloading new watch faces, etc. I am loath to try a factory reset or uninstalling the Fitbit app from my phone, but I don't know what else to try. The app's constant attempting to switch the interface seems to be draining the watch battery too. I've only had it a little over a day and the battery is down to 37%.
12-07-2019 11:35
12-07-2019 11:35
Same issue on my Versa 2.
I ended up uninstalling the app from my phone. Reinstalling. Turning of the Versa 2 then turning it back on. Solved the issue. I lost no data in my app or watch in the process. Thank goodness!
Hope this helps some of the other users having this issue.
Peace!
12-17-2019 09:27 - edited 12-17-2019 09:28
this worked for me!
@HogNation wrote:Same issue on my Versa 2.
Peace!
12-27-2019 08:25
12-27-2019 08:25
I also have a note 10 and versa 2
Best Answer12-31-2019 08:22
12-31-2019 08:22
I tried that but nothing works and it won’t sync. Very frustrating. I have 4 clockfaces that are trying to install and there’s no way to cancel them.
12-31-2019 11:41
12-31-2019 11:41
Best Answer01-19-2020 19:54
01-19-2020 19:54
I was having the same issue, I went on my watch to the "clocks" icon, and picked my original watch face. Then went back to the app on my phone and it allowed me to stop the installation and remove it.
