08-28-2018 11:49
08-28-2018 11:49
Does anyone have any experience of putting a barrier between a Versa and their skin that still allows the Versa to function? Specifically, it seems that I have an allergy to material in my Versa (not the wristband) and I'm wondering if applying clear nail polish or a screen protector applied to the underside of the watch will stop the Versa functioning. And if there will be any side-effects to this, e.g. charging, monitoring heart rate?
Best Answer08-28-2018 19:18
08-28-2018 19:18
Hello @Claire56
In the heavy industry I'm in, I work around oils and solvents, we wear a barrier cream to prevent harmful liquids from entering our skin through our pours.
It may be worth a try for you.
ALAN | VAN,B.C. Canada Community Council Member
Versa, Charge, Charge HR, Ionic, Ace, Aria 2 scale, Flyer headphones - iOS
Click here Fitbit help for more solutions
07-16-2019 23:31 - edited 07-16-2019 23:38
I placed a waterproof bandaid inside the band of the watch because of being allergic to the band. Maybe try a bandaid on the area of skin that gets irritated by the watch ,or place a thin piece of cloth ,or tissue on the area.
Best Answer10-28-2020 19:48
10-28-2020 19:48
I put gaze between mine and works fine
