08-28-2018
17:52
08:15
MarcoGFitbit
08-28-2018
17:52
08:15
MarcoGFitbit
How to sync Versa with PC. I cannot find where account is on the FB dashboard. I have a dongle which did sync twice today, but says error code now. I'm using my PC because it is virtually impossible to sync with Android and Samsung pad.
Moderator Edit: Clarified Subject + Format
Best Answer08-29-2018 08:10
08-29-2018 08:10
I had android problems and synced with my Win 10 pc a few days. I used the built in bluetooth on my Acer laptop and it worked great. Download and install the windows 10 fitbit app and go through the steps to add your Versa. Good luck!
Best Answer08-29-2018 08:21
08-29-2018 08:21
Hello @Kfcrowe, I hope you're doing well, it's nice to see you around the Fitbit Community. Thanks for joining us @Glennster, it's great to see new faces around, thanks for all your help! ![]()
@Kfcrowe, as @Glennster mentioned, if your computer is running Windows 10, you can download the Fitbit app from Microsoft Store or follow this link. After installing it and plugging your dongle, you should be able to sync your Versa. If you're using Windows 8.1, you can download the Fitbit Connect software from the same page and use it to sync your watch.
I hope this can be helpful, if there's anything else I can do for you, please feel free to reply.
12-05-2019 11:40
12-05-2019 11:40
I just got my dongle in the mail today and when I plugged it into the computer, it ran a firmware update. After the update was completed I tried to sync my Versa and it is saying that the tracker cannot be discovered. Can you help?
