01-16-2019
09:19
08:36
MarcoGFitbit
01-16-2019
09:19
08:36
MarcoGFitbit
How to set Versa up to record cycling mileage?
01-17-2019 08:41
01-17-2019 08:41
Hello @SurlyGurl, have a warm welcome to the Fitbit Community, it's great to have you on board.
I appreciate your participation in the Forums and for sharing your experience with us. First of all, in order to track your cycling activity and its distance, go to the Fitbit app and tap on Account > Versa > Exercise Shortcuts and check that "Bike" is already added to the shortcuts. If not, tap on Edit at the top of the screen and remove 1 shortcut. This will give you the chance to add another, select Bike. After that, tap on Bike and adjust its settings. Finally, sync your Versa for the changes to be applied.
Now, when you start a Cycling exercise, go to the Exercise app in your Versa and swipe until you find Bike, tap on it and start the exercise. When you finish it, you will be able to see the exercise and its distance once you sync your Versa again.
I hope this resolves your inquiry, if there's anything else we can do for you, please feel free to reply.
01-17-2019 08:41
01-17-2019 08:41
01-17-2019 10:19
01-17-2019 10:19
