06-11-2020 13:21
06-11-2020 13:21
How do you transfer music from your Mac PC to your versa 2?? I am seeing everywhere to download the Fitbit Connect app from the app store onto my computer but as far as I can see this app doesn't exist. If I click the shortcut for the app it just goes to the "sorry the page you are looking for isn't here" spot from fitbit. I am getting pretty frustrated, I would really like to use this feature. Any help would be appreciated. Thanks.
06-11-2020 13:23
06-11-2020 13:23
Hi @NA0886 you need to use the Fitbit desktop app to transfer music as the connect app doesn't really exist anymore.
Best Answer06-14-2020 15:13
06-14-2020 15:13
I am having exactly the same problem after just buying the Versa 2 yesterday. The link to fitbit app connect says "sorry this trail is broken", used a link to get the fitbit desktop app from another thread but it doesn't give the option to add Versa 2 as a new device. Specifically picked Versa 2 to be able to download music from Spotify and after 3 hours still no luck even getting to the fitbit app on my mac.
Best Answer06-14-2020 20:21
06-14-2020 20:21
Best Answer06-15-2020 03:27
06-15-2020 03:27
@416abbey wrote:I am having exactly the same problem after just buying the Versa 2 yesterday. The link to fitbit app connect says "sorry this trail is broken", used a link to get the fitbit desktop app from another thread but it doesn't give the option to add Versa 2 as a new device. Specifically picked Versa 2 to be able to download music from Spotify and after 3 hours still no luck even getting to the fitbit app on my mac.
@416abbey I know that this will give you a, "this doesn't make sense" feeling, but this is how the setup works. You cannot add a Versa 2 to your account using Fitbit Connect. You must use a compatible smartphone/tablet to add your Versa 2 to your account. But you need Fitbit Connect to transfer personal music to your Versa 2.
For other users in other countries having trouble getting Fitbit Connect, do the following:
Laurie | Maryland
