08-14-2018
00:10
09:14
MarcoGFitbit
08-14-2018
00:10
09:14
MarcoGFitbit
Hi,
This is a little bit stupid, but if you want to transfer music from your Mac/ iphone you go in circles.
So, downloaded the FitBit Connect for Mac (macos high sierra) and basically is saying there is no option for Versa (last row in the app) directing you to Mobile Setup.
Going to the Mobile (Iphone ) and saying go to your computer! A vicious circle that is making me loose any confidence over the products of this company.
08-15-2018 09:22
08-15-2018 09:22
Hello @TincaT, thanks for joining the Fitbit Community, it's great to have you on board.
Thanks fro bringing this to my attention. Please note that Fitbit Connect on Mac has an option called "Manage My Music" which you can access by right-clicking on the Fitbit icon located on the menu bar.
Keep in mind that in your Mac you can only transfer .mp3, .mp4 and .aac files. Now in order to transfer the music follow these steps:
Make sure your watch and your Mac are able to be connect to the same Wi-Fi network:
If you store music outside of the Music folder on your computer, our music service may not find your files. Add your folders to the list of folders the music service searches so it can find your playlists. To add folders:
I hope this can be helpful, if there's anything else I can do for you, please feel free to reply.
11-28-2018
16:43
08:51
MarcoGFitbit
11-28-2018
16:43
08:51
MarcoGFitbit
I've gone through this vicious cycle! I just tried this, this evening -- actually, for the past 36 hours + -- and still, Fitbit Connect on my Mac does not connect with Versa. When I right click on the Fitbit icon in the menu bar, it's looking for a sync dongle. I have a MacBook Air, very knew. What am I missing?
Moderator Edit: Format.
11-29-2018 08:54
11-29-2018 08:54
Hello @AAbb, thanks for joining the conversation, it's always a pleasure to welcome new members to the Fitbit Community.
I appreciate you have let us know about this situation and for sharing your experience. As you're using a MacBook Air, I would like to suggest you to turn off the native Bluetooth (from the computer Settings) on it before plugging in the USB dongle. If Fitbit Connect is still unable to connect, please remove the USB dongle and try using only the native Bluetooth.
Thanks for your patience and understanding, give it a try and let me know the outcome.
11-29-2018 09:39
11-29-2018 09:39
Hi MarcoGFitBit,
I've tried everything EXCEPT purchasing a dongle. I tried Bluetooth off, on Mac and on Versa. I tried Bluetooth on. I tried one off and one on. I've tried and tried and tried. 36 hours worth of trying. Looking at my wifi, I can see Versa connects. The moment I use "manage my music" on Fitbit Connect, Wifi on the Versa disconnects; the wheel spins forever. I'm on MacBook Air, 10.12. It seems Fitbit Connect does not work on this computer -- as everything else is connecting, syncing.
01-04-2019 09:26
01-04-2019 09:26
Same issue. on the iPhone it shows Versa is on the network. On the settings it says no IP on the Versa. I've tried connecting the Versa usb to the Mac, I've tried the MAC app. I Gove up =(
01-07-2019 06:45
01-07-2019 06:45
Hi,
I can not even download the fitbit connect. I was able to download another tracker for fitbit £4, and does not have the music feature, Thinking on return, cos that was the main reason I bought it and I can not use it.
01-26-2019 19:40
01-26-2019 19:40
None of this works. I've tried talking with an agent on numerous occasions and all they can suggest is sending back my Versa and they will replace it. I am on my 3rd Versa and still can't upload music so once again they said send it back and we'll send you a new one. Obviously there is something wrong with the the Versa, there are HUNDREDS of complaints and unresolved problems.
01-27-2019 08:29
01-27-2019 08:29
The irony is, when I got it last Xmas I was able to load and play music. I had to reset it when I had an iPhone sync issue and now I can’t get it to work again.
02-03-2019 09:43
02-03-2019 09:43
Hi
This DOES NOT work and it's really not acceptable. It's a massive feature of the watch and it's insane that it's this buggy (even your suggested method of almost 20 steps suggest sidestepping Bluetooth which must be because of a bug).
Where is the solve from Fitbit?
02-03-2019 10:15
02-03-2019 10:15
I finally got an agent to admit that there is a problem with the Versa. I suffered and spent countless hours on the phone with an agent trying to fix it and countless hours on my own trying to figure it out. I finally got smart and took it back and got a Charge 3.
02-03-2019 23:59
02-03-2019 23:59
I have to admit that I stopped trying and gave up ! Just a waste of time! Even if it worked the solutions proposed it s still to much , to complicated , to time consuming !
Maybe they should advert that it s not suitable for OS products.
03-04-2019 21:22
03-04-2019 21:22
I dealt with this for a while and found that the issue appears to be with using Facebook or Google to sign into your account through the Facebook Connect App on the Mac. Once you log in directly to FitBit, the app then was able to recognize my watch and I am able to load music over the Wi-Fi just fine.
I can login to the mobile app through the Facebook authentication and things work fine, just not on the computer to load music with the Versa.
04-26-2019 13:21
04-26-2019 13:21
@307Firefighter thank you so much! I have been searching all day for how to get my Versa to sync up, and all the typical bluetooth/wifi/connect app etc solutions did not work at all. I happened to see your comment just as I was resigning myself to sending the fitbit back and it works. As soon as I stopped using Facebook to sign in everything was fine. Thanks!
05-04-2019 05:44
05-04-2019 05:44
Thank you so much, been struggling to get music onto my versa... I was logged in via facebook. Have logged direct into fitbit account and yah.. music is transferring.... 🙂
05-11-2019 13:31
05-11-2019 13:31
This is what finally worked for me too!
06-13-2019 19:01
06-13-2019 19:01
We are having the same problem trying to transfer music from the desktop mac to the the Versa. I logged in using my gmail and password and we can't get it to work. Someone please help! Is there a different way to log in that we should be using?
06-27-2019 12:48
06-27-2019 12:48
These people have no idea how to write a comprehensible set of instructions. Just use your phone to listen to music.
06-27-2019 15:27
06-27-2019 15:27
07-22-2019 08:53
07-22-2019 08:53
I can't see an answer to this problem. Looking at all the posts it seems there is no answer. I have the Fitbit desktop app on my iMac. I have the Fitbit app on my iPhone 7. There was no problem it is connected to my wifi. It looks like your instructions say to click on the Fitbit icon in the tool bar of the desktop app. That does not get me to "manage my music". I can't even find that option. Is there an answer out there? I don't see anyone saying they were able to transfer music.
If you can't transfer music it would be nice to at least be able to control it like the Blaze did.
