How to turn on wifi ?
As you can see Wi-Fi is off how do I turn on ? Please x IMG_20190807_113904_kindlephoto-174726636.jpg
4 REPLIES 4
Are you having any issues with your Versa? Mine shows the same thing but everything seems to be working ok on mine. I'm wondering if that is just saying that it's not currently using wifi.
Sounds daft but when does it use Wifi then ? I am so confused lol
It uses wifi to speed up firmware updates, download apps and your music playlists. Not sure if it's anything more than that.
Thank you x
